Discussion topic: Sky constant intruptions
This message was authored by: Mish23
All programs stop and I have a black screen for about 15 seconds every half an hour
Re: Sky constant intruptions
@Mish23 Have you tried rebooting your main Q box ie
Hi @Mish23
