Discussion topic: Sky q box not working
This message was authored by: Sarah288
I am unable to switch on my main sky top box. The box in another room is also not working. I have no access to sky tv at all
Re: Sky q box not working
Hi @Sarah288
Have you tried pressing the Standby button (Amber led) on the front of the main Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
If this still doesn't switch the main Q box box on
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box.
