Discussion topic: No satelite dignal
Message posted on 20 Jul 2024 01:11 PM
No satelite dignal
No sat4lite signal
Message posted on 20 Jul 2024 01:14 PM
Re: No satelite dignal
@Nick+Gaylor
A message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
If you are connected to a communal dish you’ll need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
