Discussion topic: Sky q box not working
This message was authored by: Fergi1
Hello
my sky box keep losing it self every day now and have to turn it off at the wall for it to reset itself so I can use it again .
Re: Sky q box not working
@Fergi1 wrote:
Hello
Hi @Fergi1
Exactly what do you mean by losing itself?
Avatar for Fergi1
After it been on for a while it turns itself off and won't  start it up without turning it off at the wall
Hi @Fergi1
Looks like it could be overheating.   Assume it is well ventilated and not stacked with other devices.
If you still have the issue best to contact Sky for an Engineer
