Discussion topic: Sky q box
This message was authored by: Cl0011
Sky q box
Hi my sky q box in my bedroom isnt working it keeps coming up with problem joining your net work but the sky q box in my living room is workin fine.
Re: Sky q box
Hi @Cl0011
Reboot the mini as above.
