Discussion topic: Always q mini box
Message posted on 08 Nov 2023 06:25 PM
Always q mini box
Hi our sky mini q box keeps disconnecting from the network. Sky keeps telling us it's WiFi but we have changed it twice
Message posted on 08 Nov 2023 06:26 PM
Re: Always q mini box
Hi @Fiona24
Reboot the mini as above.
