Discussion topic: Sky q box no connection
Message posted on ‎29 Nov 2024 03:38 PM
Sky q box hasn't connected to internet for 3 days now. WiFi is working on my phone and iPad and laptop just not connecting to the sky q box. I now haven't been able to use on demand features for 3 days. Have tried resetting it, turning off, unplugging, waiting, turning on again etc. still isn't connecting.
Message posted on ‎29 Nov 2024 07:02 PM
Re: Sky q box no connection
Hi @Vmh2506
Did you complete the following?
Message posted on ‎30 Nov 2024 01:33 AM
Thank you so much for taking the time to explain it to me so clearly, I really appreciate it.
Unfortunately after doing all of that - reset on the back of the router and then network connection and pressing the WPS button - it still isn't connecting
do you think it could be a problem with my sky q box? As the internet is working on all other devices like my phone, iPad and my work laptop.
I
Message posted on ‎30 Nov 2024 09:36 AM
Hi @Vmh2506
Is your Broadband Sky??
Message posted on ‎30 Nov 2024 12:09 PM
Yes it is sky
Message posted on ‎30 Nov 2024 12:29 PM
Message posted on ‎30 Nov 2024 10:53 PM
Yes this time it did flash without me pressing it.... before I did the reset on the back that you explained I had to press the wps button to get it to flash.
Also do I just hold it down until the light is on or do I continue to hold it down?
it's just very strange that my internet/wifi is working on everything else except the TV - even my house phone is working and that's just WiFi calling so if the internet is down I have no house phone to use.
