Discussion topic: No satellite error
This message was authored by: Stacie23
No satellite error
Is there any reported issues in the TR4  area?
Re: No satellite error
@Stacie23
Satellite issues are not based on the area you're in. If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
