Discussion topic: Sky q box issues and problems
This message was authored by: Ali2
My box has stopped recording and also having to switch it off and on to watch channels.  Works for a while then same issues. Keep getting error messages and recording failed.
Re: Sky q box issues and problems
Looks like the hard drive may be failing @Ali2
See following link
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Avatar for Ali2
I am not getting hard disc error messages so don't think it is that
@Ali2
So what error messages are you seeing?
Avatar for Ali2
Im getting a Failed message and often a blue screen, then no channels work until I switch the box off and on from the power source
This message was authored by: Jjpt
I also have the same, I have to reboot each day, as it says recordings not available anymore, won't record due to powercut or I get blue screen for bbc, itv and movies. Only had the box 10 days after disk error on old box.
Avatar for Ali2
Recordings are also failing with a message saying Software Issue
