This discussion topic has been answered Discussion topic: For all Radio Channels a no satellite signal is reported.
Message posted on 20 Aug 2023 11:41 AM
For all Radio Channels a no satellite signal is reported. All tv channels are working.
Message posted on 20 Aug 2023 09:53 PM
Many thanks for your reply. I found the issue almost by chance. I noticed that Channel 5 was also showing as no satellite signal. So decided to check the two satellite cables that plug into the Sky Q main box. One of these was loose. On tightening this the radio chanels and also Channel 5 sprung back into life. Interestingly it made no difference to the signal status which remained.
Satellite Signal Locked
Signal Strenght 60
Signal Quality 90
LNB type Wideband
Message posted on 20 Aug 2023 12:13 PM
Re: For all Radio Channels a no satellite signal is reported.
@None1234
Take a look at the troubleshooting on the appropriate section of this link.
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
You may then need to contact Sky and arrange for an engineer to check the alignment of your dish. Be aware that if you’re on a communal dish system you’ll have to contact your landlord or building management company, not Sky.
Signal Strenght 60
Signal Quality 90
LNB type Wideband
