Discussion topic: Upgrade for BBC
This message was authored by: Thomas63
Upgrade for BBC
Hi  BBC no longer works and we now request an upgrade.
Re: Upgrade for BBC
The SD channels were closed.  You need to use the HD channels - these should be on 101/102.
Reboot your box if they're not.
Re: Upgrade for BBC
hi @Thomas63
If you still have an SD box  & you want a SKY Q box now then you will need to call the number on the  letter/email sent from SKY
Alternatively you could try getting a 2nd hand SKY +HD box from  the likes of ebay
BTW You may, also, wish to read some notes I have made for people considering switching from SKY +/HD to SKY Q
SKY +/HD to SKY Q
