Discussion topic: Sky q bedroom issue
This message was authored by: Mandytrouble14
Sky q bedroom issue
There was an update a few months back and since then my sky q box in the bedroom is not working properly.  It doesn't always do as you ask it too especially fast forwarding and rewinding it stops where you don't want it too or it jams. It's always jerky. I've unplugged it and reconnected but it's still the same. Even changing channel can be problematic. It takes a while to adjust to the channel.
Re: Sky q bedroom issue
@Mandytrouble14 Have you tried rebooting your main Q box ie
then
reboot the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Mandytrouble14
My friend advised me to do this so I have twice and it's still the same all jerky and taking ages to change channels. No idea what else to do.
@Mandytrouble14 how far away is the mini box from the main box
Not far it's no the next room
