Discussion topic: Sky pin
Message posted on ‎17 Jun 2024 06:46 PM
Sky pin
Message posted on ‎17 Jun 2024 06:52 PM
Re: Sky pin
Hi @Pamela+i This is a frequently asked question.
Message posted on ‎17 Jun 2024 07:15 PM - last edited: ‎17 Jun 2024 07:24 PM
Re: Sky pin
@Pamela+i wrote:
still have to enter pin on almost all channels
Once optional protection (under the control of the user) is switched off, only channels carrying post watershed content before 21:00 should have a Mandatory Daytime Protection challenge. That's typically Sky Atlantic, Documentaries and Comedy, plus several Cinema channels.
However, if you are seeing an MDP challenge on one of those channels, the Broadcasting Code insists it cannot be removed by a user.
