Discussion topic: Sky operator
Message posted on 25 Jun 2025 09:45 PM
Sky operator
I was on the phone for nearly an hour as my internet had been running slow when the call end when she was in the middle of trying to fix it. My Sky q is now not working due to no sat connection and I can't get through on the phone as they are now shut.
Message posted on 25 Jun 2025 10:12 PM
Re: Sky operator
No satellite or no broadband connection?
was the original problem related to sky Q at all or just general "slow internet"?
Message posted on 26 Jun 2025 05:18 AM
Re: Sky operator
Sounds like you'll need to call again when the lines reopen later.
If you’re now seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
