Discussion topic: Sky not working
This message was authored by: Ant50
Sky not working
My up stairs sky is saying no satellite signal . The home page is all up to see but when you scroll down to tv guide nothing just says waiting for tv schedule
Re: Sky not working
Hi @Ant50
Reboot the mini as above.
Avatar for Ant50
Re: Sky not working
My main box down stairs isn't working properly it seems like it's finding it hard to pick up broad band . Home seen have the writing up but blue squares instead of pics of programmes and when I scroll down to recordings , please wait and that's all it does. I'm sick of this it's bin 2 days you can't get hold of an engineer to talk you through this you think this is the best way it isn't if I can't get this sorted I'm cancelling it
