Discussion topic: Sky not working
Message posted on 10 Mar 2023 11:49 AM
Sky not working
When tv was turned on this morning message said
THERE IS A TECHNICHAL FAULT WITH THIS CHANNEL. PLEASE TRY AGAON LATER.
tv works ok on normal tv.
Message posted on 10 Mar 2023 11:57 AM
Sky q not working
Sky q not working.
message says there is a technical fault with this channel. Please try again later
Message posted on 10 Mar 2023 12:10 PM
Re: Sky q not working
Hi @rachael6627 Have you tried a power reboot?
Message posted on 10 Mar 2023 12:16 PM
Re: Sky not working
With the current weather does your dish have snow on it ? if so this could be the reason.
Also is it just some channels or all of them?
1x Sky Q Silver - 1x Sky Wifi Max Hub - SKY Fibre Ultrafast.
