Discussion topic: Sky not working
This message was authored by: rachael6627
Sky not working
When tv was turned on this morning message said
THERE IS A TECHNICHAL FAULT WITH THIS CHANNEL. PLEASE TRY AGAON LATER.
tv works ok on normal tv.
Avatar for rachael6627
Level 0 icon
Sky q not working
Sky q not working.
message says there is a technical fault with this channel. Please try again later
Re: Sky q not working
Hi @rachael6627   Have you tried a power reboot?
This message was authored by: Jynxy
Re: Sky not working
With the current weather does your dish have snow on it ? if so this could be the reason.
Also is it just some channels or all of them?
Sky Superuser - If i have helped you please mark as solution to help others. Thanks
1x Sky Q Silver - 1x Sky Wifi Max Hub - SKY Fibre Ultrafast.
