Discussion topic: Sky multiscreen stopped working on second mini box after moving broadband provider from sky to vodaf
This message was authored by: Jo369
After changing broadband provider from sky to Vodafone sky multi screen will not work on second mini box. Any help to resolve would be greatly appreciated
This message was authored by: DaveDrizen
Re: Sky multiscreen stopped working on second mini box after moving broadband provider from sky to v
Have you tried tuning the box of and re bootingit
The mini box do not go though you rooter to connect your router it connects to the main box directly.  So in theory  changing broad provider should have  no effect on the WiFi conetion between your skyboxes. However they both use 5ghz signals  make sure they not the same channel as that could course interference. If you can change the channel your new broadband is using. The only other  thing that may have effect your problem is if you had Sky broadband before as that acts slightly differntly  as the Sky box'sdo act as a boasters  to the internet WiFi thus second box might not now be getting a good signal from your main box
I have found some more information I presume the box that is not working displaying a message it contfindyou main box or word to that effect,   To fix this m first do a reboot on both your main box and the mini box that not working , ie swixh them both off and on again.  Then you have to do network rest on the mini box that not working. To do this  on mini box go to setting then set up then network then reset, and follow the on screen promps to reconnect using WOS button on you main Q box .  I think mini box give a indication where this button is you main box from memory when I have had to do the same procedure, The mini box will then try to connect  to you main box  and give you a onscreen message that says so, it will possably take a couple of minute to do this and then you should then have connect to your main box box and see programming on your mini box.
I have found some more information I presume the box that is not working displaying a message it can't find  main box or word to that effect,   To fix this must first do a reboot on both your main box and the mini box that are  not working , ie switch them both off and on again.  Then you have to do network reset on the mini box that not working. To do this, on mini box go to setting ,then set up, then network ,then reset, and follow the on screen promps to reconnect using WPS  button on you main Q box .  I think the mini box gives a indication where this button is on your main box from memory, when I have had to do the same procedure, The mini box will then try to connect  to you main box  and give you a onscreen message that says so, it will possably take a couple of minute to do this and then you should then have connect to your main box box and see programming on your mini box.     IHAVE REST THEPOST BECAUSE THE ORIGINAL HAD SOME SPEELING ERRORS
@Jo369 when Sky was your broadband the mini box would connect to either your main box or the router, as you no longer have Sky as your broadband provider if wanting to use wifi you need to connect your mini box to your main box by using the WPS button on both boxes
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
