Discussion topic: Sky q unsuccessful connection
This message was authored by: Sarahl2011
My sky q box can't connect to broadband, have tried everything as advised on here multiple times and still not working 😡 It will connect to my phone network and works fine but not my router. Please help it's driving me mad and can't talk to anyone just get directed to here
This message was authored by: Kerryb500
Re: Sky q unsuccessful connection
I'm having the exact same problem 😡
This message was authored by: bemak187
@Kerryb500 @Sarahl2011 Is this Sky broadband or another provider?
Hi @Sarahl2011
@Kerryb500
If you haven't already tried the following sequence exactly as follows then try it.
Avatar for Sarahl2011
Thank you so much that worked 🥳
This message was authored by: Becky30n
This is still not working ?  Sky have send a new booster and that's still not working I have had no sky tv for 2 weeks pls help
This message was authored by: Kelly120
Me too...can't connect my sky q box to SKY WiFi or router 😡😡😡
This message was authored by: DaveDrizen
If you have Sky Q you get the signal though the dish outside you should have all the Sky channels even though it won't contect to the broadband router.  Al you won't get is the internet stuff like the apps ect. Only if you have Sky glass or Sky stream do you get you channels via router. I have Sky Q and a couple of time it has not connected to WiFi properlybut it still had all my tv channels on my main box. I just the message on the Home Screen that box was not connected to the internet instead of showing all the liutke picture but mini screen was show Sky t. Yes my mini box stoped working but that could have been fixed by a reset there if I could get the main box connected to WiFi but after a network reset it did.
Also bear in mind if your Sky box goes off when it comes back on it take a good couple of minutes to connect to the WiFi and yes insherly you may get the not connected to the internet internet message on the Home Screen but this will usualydated with no normal Home Screen after 5 or 10 minutes
