Discussion topic: Sky multiroom box
Message posted on 24 May 2023 05:39 AM
Sky multiroom box
Hi, I have an outdoor man cave and I am trying to put a multiroom box in there.
it is about 50m from the house and it won't connect via wifi.
if I hard wire it then what cat Ethernet cable do I need to maintain good speeds ?
Is a cat6 cable good enough or do I need a cat8 ect ? As I can't seem to source anything over a cat6 in 50m length
many thanks Jonsie
Message posted on 24 May 2023 07:03 AM - last edited: 24 May 2023 07:05 AM
Re: Sky multiroom box
Cat5 is fine for Q, and realistically for any other domestic network requirements: it's quite capable of gigabit up to 100 metres, and you're very unlikely to have devices with better than gigabit ethernet chipsets.
A Q Mini box never demands more than about 10Mbs, while a Stream puck doing UHD/HDR is 30Mbs at most.
Message posted on 24 May 2023 02:33 PM
Hi thanks for the info, I really appreciate it
I'll give it a try
many thanks
jonsie60
