Discussion topic: Is multiroom connected by cables, or on wifi?
This message was authored by Unhappy+lhb This message was authored by: Unhappy+lhb
Im thinking to get multiroom, but put off by the thought of cables through the house. Is this the case, or are the boxes just wifi connected? Also im guessing i wont be able to use the magic eye any more, so will need to replace that with a box too?
This message was authored by Quoman7 This message was authored by: Quoman7
Re: Is multiroom connected by cables, or on wifi?
Hi @Unhappy+lhb  SKYQ Mini boxes connect to the main SKYQ box via their own wifi mesh.
This message was authored by Q-tips This message was authored by: Q-tips
You can turn off wi-fi in the engineer's menu and the Minis will still communicate with the box via wi-fi.
You could set the Mini network up via ethernet but that would require cables between all your Sky boxes and an ethernet network which isn't connected to your broadband network.
32B12C 2TB UHD Q box • Mini boxes x2 (32D0B2) • 2022 LG C2 OLED TV • Software vQ230.000.14.00L • Gigaclear gigabit FTTH broadband (935Mbps up/down) • Linksys Velop tri-band router; 3 mesh nodes • All Q boxes fully Cat6 hardwired • Q wi-fi disabled • Q picture/audio processing disabled (no sound bar) • Pixellation cured by Q170 but back again with Q190 and now every few minutes with Q210 and Q220 live broadcasts and recordings on all boxes
There's no native RF output from a main Q box.   HDMI to coaxial cable is possible, but frankly pretty pointless unless you're trying to avoid paying for the Multiscreen subscription.
Nope, turning off WiFi breaks Mini boxes unless they have ethernet connections.
Yes, should have said that the Minis need to be connected via ethernet to the broadband network. But according to my Sky engineer last week, the Sky private wi-fi network can be replaced by cables if desired.
Certainly: I just wanted to make it clear that the option to switch off WiFi on a Q box removes it entirely, rather than just disabling the 'hotspot' function and leaving the 'television' backhaul in place.
Unhappy+lhb
So no they arent cabled?
But i cant use the eye - yes trying to avoid further cost of a second box. Its only me watching, but in different rooms.
Sorry most of these answers  are too technical for me! Do i have to have an engineer visit or can an old Sky+ box be swapped out for SkyQ & mini boxes easily?
Thanks all.
An installer visit is required to change the LNB (receiver) on the satellite dish.
hi @Unhappy+lhb
I know this is slightly off topic regarding the multiscreen
but I thought you may also benefit from some notes I have put together
SKY HD to SKY Q
As @TimmyBGood  mentions in post #4 there is no RF output (i.e. old style TV aerial connections) from SKY Q so no the Magic Eye won't work.
I think some customers have managed to use 3rd party HDMI to RF converters to allow the signal to be watched in another room (but this still doesn't allow the magic eye to work - although the SKY Q bluetooth remotes are actually quite good at working from other rooms)
