Discussion topic: Sky multi-room won’t connect.
Message posted on 14 Dec 2023 02:42 PM
My Sky mini just won't connect. I'm not paid to be a technician for them but they are taking at least a week to get an engineer. The box has been disconnecting for months but I thought it was the weather. I've done the switching off at the wall bit but my TV still says can't find source. Help appreciated because skys customer support were rude.
Message posted on 14 Dec 2023 03:10 PM
Re: Sky multi-room won’t connect.
@KevG14 I know you said you have tried switching off at the wall but
Have you tried rebooting your main Q box ie
then
rebooting your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 15 Dec 2023 01:20 AM
Yes, I even updated the software. It now goes to asking for me to press the centre button <•> but when do nothing happens. Remote is otherwise working. It's a royal pain.
Message posted on 15 Dec 2023 08:45 AM
@KevG14 wrote:My Sky mini just won't connect. I'm not paid to be a technician for them but they are taking at least a week to get an engineer. The box has been disconnecting for months but I thought it was the weather. I've done the switching off at the wall bit but my TV still says can't find source. Help appreciated because skys customer support were rude.
Hi @KevG14 , Pretty sure the weather won't affect the signal from the main Sky Q box to the mini !, may I ask how far away the mini is from the main Sky Q box as it may be out of range (or just on the edge), if it is there are a few ways to solve the constant disconnection issues.
1. Request a Sky booster that sits in between the main Sky Q box and the mini
2. Use powerline adapters to connect the mini to the main Sky Q box
3. Hardwire both the boxes and your router together (most stable solution, if using this option then remember to turn off WiFi on both the main Sky Q box and the mini as WiFi seems to be the default setting on the Sky Q system)
Message posted on 15 Dec 2023 02:04 PM
Nothing to do with weather. I used to be an area manager with Sky when it first started millions of years ago. I'm certain it's either the box or even something as simple as the remote. It could even be a software update issue.
all I know bud is I have a brain tumour and TV my guilty pleasure. I'm seriously considering cancelling my £1,000 a year sky and focussing on smart TV.
shame as I see.
