Discussion topic: Sky minibox fault
Message posted on 28 Mar 2023 01:32 PM
Sky minibox fault
My minibox switches on and connects with the main box. But I cannot get the picture to enlarge, cannot change channel and cannot select any options such as recordings etc. I have rebooted both the mini box and the main box, ried different remotes but still cannot get the minibox to work correctly. Does it need to be replaced or is there a way to get it working again?
Message posted on 28 Mar 2023 01:40 PM
Re: Sky minibox fault
Hi @G+and+C
First
Once the main Q box is back up and running reboot the mini again.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your Sky Q remote or if this is not working press the standby button on the front of the mini box (Amber led)
If the mini still has an issue carry out a Reset settings in the mini hidden menu. Similar process to the main Q Box above.
Message posted on 28 Mar 2023 01:44 PM
hi @G+and+C
Just checking - when you say you have tried fifferent remotes - did you reset them by pressing & holding 7 & 9 Together until the red led above the SKY logo flassed 4 times ?
Message posted on 28 Mar 2023 02:05 PM
I have done all of the above but the mini box still does not do anything other than switch on. I get a small picture in top left corner and get sound. But cannot get full size picture and cannot scroll down the menu list so cannot select settings or hidden settings
