Discussion topic: Sky mini
Message posted on 07 Dec 2024 06:36 PM
Sky mini
Hi, how much are sky mini boxes so my daughter can watch all Chanel's in her room?
Message posted on 07 Dec 2024 06:42 PM
Re: Sky mini
@Lou120
Mini boxes are loaned to you. You can't buy one. You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
Message posted on 07 Dec 2024 06:48 PM
Re: Sky mini
£50 is the likely answer, caveat the stuff posted by @Daniel0210
A multiroom sub will likely cost around £15pm
