Discussion topic: Sky mini boxes not working
Message posted on 02 Jan 2024 10:30 AM
None of my sky mini boxes are working
Message posted on 02 Jan 2024 11:07 AM
							Re: Sky mini boxes not working
Hi @Michael24
Reboot the minis as above.  Start with the one nearest to the main Q box.
Message posted on 27 Mar 2024 08:38 PM
None of my sky q mini boxes are working we have rebooted several times, reset the wifi done the wps button thing nothing is working
