Discussion topic: No connection
Message posted on 27 Mar 2024 09:02 PM
No connection
My sky tv box in my bedroom is not working it's saying there's no connection
Message posted on 27 Mar 2024 09:05 PM
Re: No connection
Hi @Neversober
Assume this is a mini box.
Reboot the mini as above.
