19 Feb 2024 08:52 PM
The router is ON. But the sky mini router are responding.
19 Feb 2024 09:01 PM
Hi @Weston1
Reboot the mini as above. Start with the mini nearest to the main Q box.
When you carry out the Network reset on the second mini you can use the first mini for WPS if nearer than the main Q box.
