2
This discussion topic has been answered Discussion topic: No sound after pausing
This message was authored by: Sharon_31
While watching live TV if it's paused even for a few minutes, when I then press play again there is no sound. I have to come out of the Programme and go back in for the sound to come back
Re: No sound after pausing
Hi @Sharon_31
Hi @Sharon_31
Avatar for Sharon_31
Brilliant, so far so good!! Cheers! 🙂
