Discussion topic: Sky mini box
This message was authored by: Mikea-1
Sky mini box
My sky mini box keeps disconnecting. Nothing has changed with any other equipment. Keeps happening alot and getting fed up with. Going to cancel sky at end of contract in November as now get a silly price from £65 to £83.
Re: Sky mini box
Hi @Mikea-1
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
