Discussion topic: Sky Mini Box is working but…
Message posted on 13 Sep 2026 05:48 PM
....it will not show TV pictures. Everything loads, good internet connection, but as soon as I select a channel, the screen goes blue, it looks like it's about to show the picture, but just remains blue.
I have changed the HDMI cable, used a different port, followed a power down, unplug and restart etc. I just can't get a TV picture. I am searching through the Sky Guides, it says I may need and engineer, but when I click the link, it takes me to 'page not found'.
I did see a post where the person described a similar problem, back in 2023, but I couldn't see what the resolution was.
Presumably, there is no contact number I can call?
Any advice would be appreciated!
Message posted on 13 Sep 2026 09:03 PM
Re: Sky Mini Box is working but…
I did see a post where the person described a similar problem, back in 2023, but I couldn't see what the resolution was.Presumably, there is no contact number I can call?
Hi @PAJR
Try the following:-
First reboot the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
