Discussion topic: Sky mini box
This message was authored by: Tosh1978
Sky mini box
Hi,
my sky q mini box is tuck on step 3 obtaining an IP address.
Re: Sky mini box
@Tosh1978 wrote:
Hi,
Hi @Tosh1978
Reboot the mini as above.
