Discussion topic: Sky mini box
Message posted on 10 Oct 2023 11:04 AM
Sky mini box
Mini Box NOT connecting
Message posted on 10 Oct 2023 11:09 AM
Re: Sky mini box
Hi @Prez2020
Reboot the mini as above.
