Discussion topic: 1m having trouble with sky q connection and broadband connection
Message posted on 10 Oct 2023 10:40 AM
It connects then a message comes up no Internet connection then no signal and everything freezes
Message posted on 10 Oct 2023 10:50 AM
Re: 1m having trouble with sky q connection and broadband connection
Hi @Grouseman10
Have you carried out a Network as follows:
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
