Discussion topic: Sky mini box won’t connect
Message posted on 10 Sep 2024 07:07 PM
Sky mini box won't connect
Message posted on 10 Sep 2024 07:21 PM
Re: Sky mini box won’t connect
Hi @Knocker61
I have deleted your second post as there is no need to post twice either same issue.
Regarding your issue
Reboot the mini as above.
