Discussion topic: Sky mini box stuck on 1 channel
This message was authored by Smed22 This message was authored by: Smed22
Sky mini box stuck on 1 channell
Re: Sky mini box stuck on 1 channel
Hi @Smed22
Have you tried rebooting your mini box?
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
note: some features may take up to 5 minutes to return
If you had press. The standby button to bring the mini on then
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
