Discussion topic: Sky mini box remote
Message posted on 23 Apr 2024 08:07 PM
Sky mini box remote
Sky remote won't connect to mini box after reset?
Message posted on 23 Apr 2024 08:29 PM
Re: Sky mini box remote
Hi @Jaymz
First reboot the mini.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
If the Remote is still not connecting.
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Message posted on 23 Apr 2024 08:32 PM
Thank you but I've tried all of that 👍
Message posted on 23 Apr 2024 08:38 PM - last edited: 23 Apr 2024 08:38 PM
Message posted on 23 Apr 2024 08:41 PM
The amber light.
when the box boots up now it asks if it's the first time I've connected it.
The remote won't connect to the box for me to do anything
Message posted on 23 Apr 2024 08:43 PM
