23 Apr 2024 09:19 PM
We have 2 additional sky q boxes . If we are watching one and the main box is switched on the sky q looses its connection . Sometimes it will come back on with in a few minutes but the majority of the times we have to reset the sky q box . The main box continues to work ok . This is really frustrating. We get a message on the sky q box box saying there is a technical fault on this channel please try again later .
really need some help with this
23 Apr 2024 09:26 PM
Hi @Qsw1953
First
Try a Reset Settings in the main Q box hidden menu.
See if you have the same issue.
