09 Oct 2023 06:34 PM
I've been watch tv from my sky mini box in the bedroom and it's suddenly stopped working. When I press the menu button the small box at top left corner appears but the rest of the screen is blank. I can load the program in the little box and scroll the some random channels that don't seem to be sky channels. I've turned both tv and mini box off and restarted but nothing changed.
09 Oct 2023 06:50 PM
Hi @M1chaela
Reboot the mini as above.
28 Nov 2024 09:11 PM
Worst company ever doesn't work
