Discussion topic: Sky box
This message was authored by: Caerdydd2
Sky box
My sky box power button not powering
Re: Sky box
Hi @Caerdydd2
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
