Discussion topic: Non of our sky boxes connecting to internet
Message posted on 28 Nov 2024 09:15 PM
We have 3 sky boxes in our house; one sky Q box and 2 sky mini boxes.
All 3 boxes are failing to connect to the WiFi. But the WiFi is working as all our phones are working and the box is showing the correct light. The problem seems to be with all our sky boxes. The red light is on on our sky boxes. We have tried to reset the WiFi in settings, but this doesn't do anything and it fails every time.
Message posted on 28 Nov 2024 09:18 PM
Re: Non of our sky boxes connecting to internet
Hi @Katherine17
Did you complete the following?
Wait until the router is completely back and running and then try a Network Reset found in main Q box Home - Settings - Setup - Network.
