Discussion topic: Sky mini box not working
This message was authored by: palmerm
Sky mini box not connecting to normal q box
Re: Sky mini box not working
Hi @palmerm
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
