Discussion topic: I have a tv that I’m having trouble getting sky.. a guest has done something to it. I can’t fix it..
Message posted on 04 Jul 2023 12:00 PM
It's a mini box that I need help getting sky linked in.. a guest did something.. all other TVs are working fine so it's something simple but I can fix it on my own. Thankyou Wendy
Message posted on 04 Jul 2023 12:14 PM
Re: I have a tv that I’m having trouble getting sky.. a guest has done something to it. I can’t fix
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
If you had to press the standby button onthe front of the mini to turn it on then you need to reset the mini remote control.
To do this make sure the mini is on with green LED and then
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
