Discussion topic: Sky mini box not showing pictures on any channels
This message was authored by: bobbyw2ilson
my mini box home page loads up ok but when you pock a channel no picture appears and a technical error comes up at top of screen and says try later
Re: Sky mini box not showing pictures on any channels
Hi @bobbyw2ilson
Reboot the mini as above.
