Discussion topic: Sky mini box not powering up
This message was authored by: ColinRimmer
Had the electric off for a lighting switch repair
when back on the mini box says it's getting started don't turn off goes blank the says press home when it goes blank again but then the remote won't let me pick a option
Re: Sky mini box not powering up
Try rebooting the mini again @ColinRimmer
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
If this turns the mini box on then
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
