Discussion topic: Saying no satellite signal
Message posted on 17 Sep 2024 06:47 PM
Hi unable to get sky programmes on n stating no satellite signal however should be running off Wi-Fi
Message posted on 17 Sep 2024 06:50 PM
Re: Saying no satellite signal
It's nothing to do with Wi-Fi. If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Message posted on 18 Sep 2024 06:31 AM
Sky Q depends on a satellite signal even though it can access a lot of content via the internet.
You do have a dish installed?
Message posted on 18 Sep 2024 09:04 AM
Hi the main sky box is working, however the additional room box is saying no satalite signal?
Watching gold on the main box but waiting for tv schedule on the additional box?
Message posted on 18 Sep 2024 09:36 AM
@Jp4077 wrote:Hi the main sky box is working, however the additional room box is saying no satalite signal?
Have you tried power-cycling the mini?
Message posted on 18 Sep 2024 12:15 PM
Yes, standby, unplugged, restarted, check connection to main box and wifi, netflix etc works but no sky channels, main box still working
Message posted on 18 Sep 2024 04:48 PM
@Jp4077 Have you tried rebooting your main Q box ie
then
rebooting your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
