Discussion topic: Sky mini box not connecting
Message posted on 14 Apr 2024 11:49 AM
Hi,
we have been trying to connect our sky mini to sky q and keep getting either m004 error or m012
habe tried resetting switching both boxes off connecting and re connecting to internet and still get the error
can someone help?
Message posted on 14 Apr 2024 11:52 AM
Re: Sky mini box not connecting
@Moniqueparmar wrote:
Hi,
can someone help?
Try the complete procedure again.
Reboot the mini as above.
