7
This discussion topic has been answered Discussion topic: Pixellation on all (1x Sky Q and 3x Mini) boxes
This message was authored by: Skywatcher5888
Sky has been installed for several years at my home.  Recently, getting pixellation - approx once every 5-10 minutes - on all channels.  Signal strength steady at 70%, with quality 90%, same as when it was installed.  Both the dish (it's installed about 2m off the ground) and cabling look OK from visual inspection. I've rebooted the Q box, and performed a factory reset - no difference.
How do I get this addressed please?  Does it need an Engineer visit and what would the cost for this be please?
Thanks,
Steve
Re: Pixellation on all (1x Sky Q and 3x Mini) boxes
Thanks,
Steve
Hi @Skywatcher5888
Certainly best to contact Sky for an Engineer.
Provided it is a Sky Q box then these are all owned by Sky and if faulty will be replaced FOC.
Thanks,
Steve
Hi @Skywatcher5888
Avatar for Skywatcher5888
Thanks @oldfella .  Do Sky support monitor these chats, or do I need to contact them directly?
This message was authored by: ThePope27
@Skywatcher5888 Sometimes it gets escalated directly from the forum 🙂
There isn't any trees that are blowing in the wind and blocking signal for a split second is there ?
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
You'd have to initiate contact.
Thanks @ThePope27 .  No, no change in the installation.  Should have direct line of sight of the satellite.
You are bestto contact them.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
@PandJ2020
That's quite contradictory to what I've seen on the forum,
Some people escalate to sky directly from here and then direct message them ?
