Discussion topic: Netflix
This message was authored by: Wicked55
Netflix
Why is my Netflix Spanish & I can't use it ??????
This message was authored by: ThePope27
Re: Netflix
Either your account has been compromised or someone might have accidentally changed it.
Please do this on your PC or Netflix app on a phone/tablet, this will not work on the Sky Q app
Instructions For Desktop/Laptop
  1. If you are on the log in screen, select "Manage Profiles." If you are on the home screen, go to your icon in the top right, open the option list and then select "Manage Profiles."
  2. Click your profile icon.
  3. Go to "Language" and open the list options.
  4. Select your preferred display language and hit save.
Instructions for Phone/Tablet
  1. Open the Netflix app.
  2. In the lower right, tap My Netflix
  3. In the upper right, tap the Menu
  4. Tap Manage Profiles
  5. Select the profile you want to edit.
  6. Tap Display Language
  7. Select a language. The new language will automatically save
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
This message was authored by: best+of+the+best
Re: Netflix
That method will only work if the maximum amount of profiles hasn't been created and they haven't pin locked the main profile
If you manage to regain control of your Netflix account make sure you change your password and make sure the Sign out of all devices is ticked before you press save.
If you don't any devices you are currently signed into with Netflix will retain the old password apart for the device you changed the new password to.
Re: Netflix
@Wicked55 the normal explanation is that your account has been hackrd and you need to contact netflix to sort this
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
