Discussion topic: Sky mini box keeps freezing
This message was authored by: John6636
I'm having problems with my sky mini box it keeps freezing when try to watch a program the box was replaced a few months ago but this didn't make a difference
Re: Sky mini box keeps freezing
Hi @John6636
Reboot the mini as above.
This message was authored by: Tiny+d
HI
I have same problem  ,Sky Q  mini picture freezes , i have had 2 engineers out so far  both saying connectivity if good ( i have a  Sky router next door in bedroom ) Updates are all correct and inline with the main Qbox down stairs ,we did all the above ,switched off main ,reset mini and it works for about a week then picture freezes again .
I can watch other App like prime /netflix,Etc but  not SKY programes ,movies etc .
I have changes the HDMI lead ,check power lead still nothing works ,so 2x engineers 2x new boxes , could it be the TV ? this is 3 years old samsung .
Didn't have this problem with he SKY HD box and same TV .
