Discussion topic: Sky mini box dropping the network connection via the sender, from main Sky Q box
Message posted on 27 Oct 2023 12:14 PM
Sky Q box is in main cinema room
also have two Sky mini boxes , one( furthest away ) hard wired Ethernet is no problem , the other much closer is dependent on a sky EE120 sender passing on the signal .
this works pretty inconsistently and constantly needs reconnection via pressing the pairing buttons 3or 4 times a week ..mini box connects to my home network ( ie the wrong network ) as opposed to the sky sender / signal
Message posted on 27 Oct 2023 12:19 PM
Re: Sky mini box dropping the network connection via the sender, from main Sky Q box
Hi @LG+Oled
Are you carrying out a Network reset on the mini box or just pressing the WPS buttons?
